Thank you everyone in advance.
There is no announced release date. Netgear is touting it off though in video's recently at CES, so I would imagine it would be released soon.
I just received my Arlo Pro silicone skins at the first of the year, and Amazon was a pretty good indicator of when they were to be expected in stock, actually sooner than planned. Amazon currently shows no indication of stock for the charging station, though, so no help there.
I added a camera to my 4-pk by purchasing the $189 add-on box. It came with another charging adapter/cable so I no longer have a need for the dual charge station, unless I were to stock extra batteries, which I don't currently plan on doing. If you are considering another camera, just remember that you will then be able to charge two at once anyway. Should be the same downtime for the cameras unless you were planning to buy spare batteries with your charging station.
That's a good question, and I had the same concern. However, the only thing that will be distrupted is the camera angle/position. All the other configuration with modes and rules will remain the same. If you are using the included magnetic mounts, I would be seriously impressed if you were able to switch out batteries without moving the camera position. If you have security mounts for all of them, then that could make more sense.
So to answer your question I am removing them and charging with the cable, in which case I actually find the security threaded mount to be a bit of a pain (when I screwed the camera back on, it didn't end up in the same position so I had to use both hands to adjust/tighten ... perhaps I should have just tried to open the battery compartment while leaving it mounted), so I recently replaced it with one of the magnetic table/ceiling mounts that is a full ball joint and stands off the surface about two or three inches. Now I can make quick position adjustments with just one hand while I review the screen in position mode on the app.
