Arlo pro. Can't get past add device screen
Go to setting... go to camera, use REMOVE DEVICE.
Power button reboot the base, now try and bring it back as new
No luck with that approach, can't even get to a remove device screen. unplugged router, resert router, removed batteries, let it sit about an hour, synced cameras, rebooted app on my iphone, but nothing comes up when I hit devices except add device. Settings and calender icons seem to work fine. Is there some way to strip it all down and start as though it was a new device just out of the box?
WHat are the LEDs on the base showing? Should be 3 green ones.
All 3 green lights are on after what appears to be a successful syncing. Perhaps the problen is with my iphone. Is there a way to wipe out the account and start over from scratch with both the app as well as the hardware? I have tried rebooting app and that does not work.
Went through the removal process for the devices but the app is semi-locked and I can't do more. Is there a help line where I can speak with a person? If I can get Arlo to delete my account at their end I might be able to start over. Willing to try anything as all I have now is a $500 paperweight. The shame of it is it worked so well for 4 days and then went off the rails.
Use a browser - it may well be easier. A reinstall of the app may help, too.
Support is available using the Contact Support link at the bottom of the desktop version of these pages.
