Arlo pro 15-20 seconds leg on live view
  • 7 Replies
  • 3483 Views
  • 5 In Conversation
Mtb308
Please help .... my Arlo pro has a major lag time when view live...up to 20 seconds delay ...which makes 2 way communication useless.
7 REPLIES 7
Johnny290
Mentor
Mentor
Me 2
What devcies are you using ... OS versions.
Also , contact Netgear Support as if the problem is with the app, they can't fix it if unaware.
Johnny290
Mentor
Mentor
Arlo pro
Tom meant computer and/or phone and which OS versions.  The audio lag can be dependent on the exact device and OS.
Retired_Member
Not applicable
Mtb,
Also, what's the status of your connection?
* Do you have a connection that can support Arlo Pro?
* Do you have any excessive lengths that may inhibit wireless connectivity?
* What is your internet service like? Slow, spotty, non-reputable company?
Some thoughts that occurred to me.
Good luck,
Dave
Johnny290
Mentor
Mentor
15 second leg is on Android that's for the video. The internet speed is 50,50 down and up load speed. Verizon FiOS is the internet provider very reliable . The cameras are not too far away I have 3 bars.
Johnny290
Mentor
Mentor
I also have iPad there still is a lag when trying to view the live feeds . This happens weather using Wi-Fi or cellular service
