My Arlo Pro stopped sendimng notifications this morning. I rebooted my phone and everything was fine until this evening and again no notifications. The cameras are recording but not sending notifiction
Since March1, I don't get notifications anymore. howcome? This is for both "free" cameras as well as "paid" cameras.....
FWIW, I am getting them.
Are you still getting recordings?
There have been some other folks reporting issues with notifications - they should have been resolved by Arlo yesterday. So perhaps wait a bit. https://status.arlo.com/
I was getting sporadic notifications yesterday but today I'm getting nothing. I just rebooted my base, perhaps that will resolve it. I'm not home so I won't know until something is detected. It is, however, recording as I can see the recordings in the cloud.
Well again this morning failed to get a notification for motion on a video that is in the library, starting to get old. If it's in the library it's not likely a hardware issue. It's only the two of seven set for motion notifications that have an issue and only with motion and yes all the resets and turn off turn on have been done.
Hi @Astronomy @Retired_Member
Have you tried rebooting the base station or cameras & test again? You can reboot the cameras by removing > re-inserting the battery.
May I ask which troubleshooting steps you have performed so far? I don't want to suggest any prior methods you have previously performed.
Mysteriously, things started working again in the middle of the night.
I truly believe there are software issues - when using a browser, I can watch a camera detect motion and record. I then see the "badge counter " change from indicating 0 recordings to showing 1 recording, and then immediately changing back to a zero again, all in a second or two.
