Arlo device is offline 1 of 2 CAMs
  • 7 Replies
  • 4862 Views
  • 2 Likes
  • 7 In Conversation
Chrom
Received two CAM Arlo PRO package.  Followed all instructions and successfully added and viewed first of two CAMS.   Attempted second CAM and either would not sync or took forever to sync.  Once shown in APP the second CAM quickly stated device is offline.  This happened a few times without correction.  Reset CAM following protocol and end result is still the same.  This appears to be an ongoing issue as noted throughout the community.  Not a happy first time user.
7 REPLIES 7
Is the battery charged? You might want to try plugging it in and see if the same thing happens.
Gti337
This is happening to me right now. I got the package that comes with 4 cameras, and one of them its doing what you said before about stating device offline. I already opened a case with support just waiting on the responde or help.
Chrom,
As suggested above, did you try plugging the camera in? Do you still see the same behavior? Please let us know.
Natt1979
Same thing here, only 1 camera got messed-up. I removed my device from my cellphone, I might add it later when I get home. One more that I noticed, that the battery charge went down so fast. Unlike the other 3 cameras.
watchdog99
Luminary
Luminary
what I've noticed is when a camera goes offline and remains offline it drains the battery pretty fast. probably due to it repeatedly trying to reconnect to the base.
greatoz99
Similar thing happened with me, I had a 2 camera kit, one camera quickly went offline. After walking thru troubleshooting steps with support they sent me a new battery. Started happening again, they are replacing my camera.
Note above make sense that the battery drains quicly trying to attached to base station...but it's either the battery or the camera, so it makes sense just to get them both replaced..
Natt1979
That exacty what happened to mine, what i did i remove rhe battery. And charge it, and i will try to add device again. I will see what happen next.
