Arlo bad picture and says signal is weak, 5 ft away from a WAP
  • 2 Replies
  • 2045 Views
JSpike
We have ARLO Cameras throughout our church campus. They all run off the same network of Aruba WAPs. For some reason, I have one ARLO Camera (not a pro) that is 5 ft away from a WAP with perfect signal (tested at 110M) but the picture comes through bad and says signal is weak.
Streak2
Master Master
If it's Arlo Pro or Pro 2 cameras you are talking about then they do not connect directly to your WAP's but connect via an Arlo base station which may be connected to your WAP.
How far is this camera from it's nearest base station (assuming you have more than one).
The only way to really expand coverage is using multi bases and link the closest cams to each.
( no limit on number of bases on any service level )
