I picked this up from Amazon and installed it Thursday. I pulled the camera down and charged it to 100% before plugging it in. Everything looked great, the camera showed at 100% and charging. The next morning I had a red exclaimation point and "The charging source connected to the camera cannot charge your battery. Please use an Arlo Pro power adapter" showing in my interface. Upon contacting help, they asked me to remove the panel and allow the camera to discharge to 50% before plugging it in again. I let them know that this wasn't at all helpful as it will take a few months to get to that point, and I cannot return the item after this long. I specifically asked if there was firmware that addressed the variable wattage input a solar panel will provide and they said that they would look into it and be in contact. I'm underwhelmed with the help. I pulled my other camera and the same message is provided (that camera was charged to 74%).
Has anyone else tried the Arlo solar panel and had luckl?
banking wrote:The issue is how you plug the Solar Panel connection to the camera, I had a difficult time. Here is what you need to do:
(1) When you plug the Arlo Solar Panel connection to the camera, make sure you rub the male connection against the TOP part of the back of the camera female connection and push in tight
(2) You will know when it is plugged in when it snaps in.
I tried it finally and it receive a charged, thank you, I hate climbing ladders too much and this camera definitely needs the solar panel. I am glad I tried it one more time before taking it back. Now, I can go get one more for the other camera that needs, these are 2 trouble spots that must be monitored.
Congratulation! I prefer to find the root cause by myself rather than return to solar, cause someday still need to change the battery, solar panel is a MUST for this camera. I will try to ask more people try my solution to prove the solar panel works fine indeed.
jguerdat wrote:I've had issues with plugging the cable (both solar and outdoor power supply) myself. It IS difficult to do so the best you can hope for is to take your time and ensure full/proper seating.
I agree with you, it is difficult to pluging the cable, but as you know hard to plug in also means had better waterproof, that is tradeoff, so do it right at the beginning, can save your time in the future. 🙂
I had this error message the first day after setting up my solar panel. I went home that night and tried unplugging and reconnecting the camera end. Didn't help. I tried the same thing with the cable that plugs into the solar panel. This fixed it!
That end of the plug is hard to connect properly (due to weather sealing I'm sure), but once seated it seems to work fine. I'll monitor and report back if it changes, but it seems like the stiffness of that connection is the only problem here. With some effort, it seems resolvable.
The problem I am finding and so are many is the trying to plug the Solar Panel connection into the Arlo camera.
(a) If you try to plug the Arlo solar panel male connection into the Arlo Camera female connection when the camera IS NOT mounted it is easy and you can check if the solar panel is working; of course, you want to be make sure the Arlo Solar Panel is direct sunlight when trying this.
(b) Most people are having a problem plugging the Arlo Solar panel male connection into the Arlo camera female connection when IT IS MOUNTED, that darn round piece gets in the way when you are trying to plug it in. It makes it hard to go straight in the back of the camera.
A solution:
(1) While the camera is mounted, take the Arlo Solar Panel male connection and go forward and upward some into the back of the camera so you rub the bottom of the round piece of the mount.
(2) Once you are able to push the connection further into the back of the camera, while the Arlo Solar Panel connection is rubbing against the bottom of the round piece of the camera mount, then push forward some more and downward some and this should work. You will feel the Arlo Solar Panel male connection snap right in.
***DO NOT JUST JAM THE Arlo Solar Panel connection in the back of the Camera or you may bend the Arlo Solar Panel male connection and/or Arlo Camera female connection.***
I know it is a pain to plug in the connection while the camera is mounted but it worked for me. Check the camera status charge icon and if you see the charge icon then it is working, of course, you want to try this while the Arlo Solar panel is in direct sunlight.
My mounts had a mix of old and new so I just switched mine around to meet my needs.
I also plugged the cable into the camera first, then screwed the camera onto the mount. It was a bit fiddly but it worked. Once the camera was mounted, I plugged the other end of the cable into the solar panel.
I've had no issues with my panel.
-Bob
There is no doubt that the Arlo Solar Panel is working, the majority of the issues are plugging the Arlo Solar Panel into the Arlo Camera. Someone was thinking about trying a differnt solar panel that was not Arlo and I told him not recommended because it may cause problems with your camera and void the warranty if something happens.
My solar panel worked for about a week, no I get the "The charging source connected to the camera cannot charge your battery. Please use an Arlo Pro power adapter" message. The panel kept my battery at 100% during the day, now all of a sudden this message. No idea what triggered it. I called support, and opened a ticket.
Try unplugging both ends of the cable and replugging, taking the time to ensure the connectors are properly and fully seated. Some folks have had success doing this.
Seems replug cable is one of the solution to fix this issue.
I've tried this at least 40 times and it doesn't work. I've tried everything and it works for a little while up to a couple of days then I get the red ! again. They always work for a bit then stop working again. This is getting old really fast.
I thought i was good after resetting the camera few days ago. Sit was even working after raining all day. I checked the status this afternoon and it was back to not charging the camera. This is very frustrating. I still feel it has something to do with the cable connection at the camera. I decided to return a second solar panel that i did not install yet to wait until this issue s resolved.
It may not be fully plugged into the camera all the way, you can contact Netgear and request a small locking nutt for the mount and then it will be easier to plug the Arlo Solar Panel into the camera. That big locking nutt on the mount is making it difficult to plug the Arlo Solar Panel male connector into the Camera female connection.
Sounds like the solar panel is not ready for prime time yet.
When you call support, the front line level 1 just reads from a playbook that calls for reboot, reseat, etc. IMO they don't know and are not engineers etc.
But I can tell from the effort it takes to plug in that cable that a solid connection is hard to make, and could possibly be loosened later by varying temps and weather exposure. Perhaps for those having problems it would help to lightly lubricate the sides of the plug with oil or grease before plugging it in firmly.
Netgear should do a much better job educating their support staff. They should be well versed in this by now.
But I would not dismiss the value of the product otherwise. It does seem possible to make it work reliably, though results may vary due to manufacturing variations.
Be careful with that! Use a waterproof dielectric grease very sparingly if you're going to do this. Make sure to stay clear of the contacts.
And have you tried what's been suggested here and in other threads about reseating the cable on both ends?
Or improperly/incompletely connected. It's certainly possible to remove the connector from the panel.
Pulled the usb plug out then back in and this time just a blue flashing connection light and no error! I have to say the usb port on the camera looks a little "tainted"
This is a comment I sent to the Arlo Support Team
Dear Netgear Support,
Does Netgear have a small locking nutt for the mounts, the big locking nutt maybe the issue that many customers have when connecting the Arlo Solar Panel male connection to the Camera's female connection, that big locking nutt makes it very difficult for a customer to connect the Arlo Solar Panel's male connection to the Camera's female connection.
The issue with the Arlo Solar Panel not charging properly could be the Arlo Solar Panel's male connection IS NOT FULLY connected the Camera's female connection. I have 2 Solar Panels and are they are still up and running after 2 weeks, but in the beginning I had difficult time plugging my Arlo Solar Panel's male connection into the Camera's female connection. A small locking nutt for the mount maybe the solution. This will allow the customer to connect the Arlo Solar Panel's male connection to the Camera's female connection in solid without an problem
