I have 2 Arlo Pros and I keep them on a schedule to be disarmed when I am home during the day and record video/ring alarm when I am normally sleeping or at work. However, I have noticed that my schedule is no longer having an effect on the mode. When I set the mode to disarm, and then set it to schedule, the mode stays on disarm (the previous setting) regardless of the schedule. The same goes with other modes. When I set the mode to 'Vacation' and then set the mode to schedule, the mode stays on 'Vacation' regardless of the schedule. Any help here would be greatly appreciated.
Try power cycling the base. Also, try the app or browser, whichever you aren't currently using. Any difference?
jb1233,
Are you still seeing this behavior after the suggestions above? Please let us know.
I'm no longer seeing this issue. This started working again without any action taken on my part. Thank you for the help.
timos68,
Are you sure you have the correct mode selected for the right scheduled times? Check your schedule to ensure the correct mode is set for the desired time frames and try again.
timos68,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
