  • 4 Replies
  • 3310 Views
  • 3 Likes
Guy2
After recharging one of my cameras it won’t connect. It was working before I charged it. Now when I insert the battery I get one blue blink and two amber blinks. Using the sync button only make the amber light flash twice. Thanks
Guy
Swap batteries to see if it's the camera or battery. What happens if you use AC power, both wioth and without the battery?
KLD10
I have the same problem. Tried plugging it in, new battery, all sorts of resets, same problem. Did you fix your issue?
Also tried this tread: https://community.arlo.com/t5/Arlo-Pro/When-holding-down-sync-button-on-Arlo-Pro-to-add-to-new-Base/...
If you think it's a hardware problem, use the Contact Support link at the bottom here.
Guy2
Nothing that I have tried has worked. Did you have to get a replacement camera?
