Arlo Pro setting up mode problem
Ok so I'm trying to work with this thing. I'm having a problem setting up a specific mode. I want to use the regular Armed mode when I'm not home. When I am home I want:
Front Door: On/Motion Detecting
Back Door: On/Motion Detecting
Living Room: Off
Seems simple. And it probably is but here's the problem I'm running into.
I add a mode called Outdoor Armed. I select Front Door and set it up so that it will be armed. Easy. However, I can't add any more IF statements, only THEN statements. And I can only add extra devices for the THEN statement. For example, IF the Front Door motion detector is activated THEN record Front Door. I can add record Back Door as well... but only IF the Front Door detects motion and not the Back Door.
Basically, I can only have one device trigger an event at one time. I can't have both my Front Door and Back Door motion detect and record and especially not even turn off the Living Room camera. I want all of those to happen at the same time.
Living Room: Off
Any suggestions?
Wait, I may have figured it out. Under modes you can add seperate rules. Wasn't quite intuitive to figure out since I had to go back through my mode searching for how to edit things but whatever. I'll see if this works.
Once you add and save the first camera...you can always go back and edit to the additional
Remember, any camera NOT in the active mode is OFF
