Arlo Pro not recording or sending notifications
  • 3180 Views
GoneD
Hi,
Tonight i try to test my camera if is detect movement.
I put my mode to ARMED, and try to detect me...nothing, i see in the APP an yellow detection icon...but no record...no notification.
I have an Arlo Pro (4 cameras) with VMB4000 Base station.
I have try to remove camera / reset base station to reconfigure all my cameras....but...now..is not possible to add my camera....base station is ok in my account but when i try to add camera i push the sync button blink and fast blink but NOTHING...my cameras is not in my ARLO account....
I need help....lol thanks
GoneD
Ok i have found the problem.
I use DNS over SSL (DoT) and the base station not accept this...i have exclude the base station to use directly favorite DNS like Google.
Thanks for support
Perhaps try this from the web client (https://my.arlo.com).
If that fails, contact support: https://www.arlo.com/en-us/support/contact.aspx
GoneD
Ok after some test....
The problem is from my wifi router....and 2.4 Ghz channel interference....
Why the base station is choose the same channel....is very weird..and no good idea to do that....
What is the best solution ???? i want to sell my Arlo Pro....is very bad from Arlo/Netgear this technical solution to choose same channel...
GoneD
Thanks for support
