Arlo Pro motion detector won't stop once it starts
I am having issues with one of my cameras. When it is armed to record for motion, it will work properly the first time. Then, it won't stop, even when there is no motion. I have to turn it off. Is anyone else having this problem? I have adjusted the sensor down to about nothing and it still does it. Thoughts?
I've tried it with and without.
This does work for me as well, but unfortunately as soon as it legitimately goes off for motion detection again, it keeps repeating. Just a pain 🙂
garyh526,
Is this happening only at Night or does this happen regardless of the time of day?
That's a good question. Haven't thought about it. I guess I would say mostly evenings and night.
The engineering team is currently investigating this issue. We will provide an update as soon as a solution is confirmed.
We appreciate your patience in this process.
Thank you so much. Would be nice not to have to constantly reset it! 🙂
My arlo pro is doing the same thing. All the reasons I bought the camera for have been turned off and rain seems to set off the motion and runs until the schedule turns it off or the battery dies. Please fix! BTW new camera old base.
Any help would be greatly appreciated.
Have you opened a case with support?
Yes, I have.
Engineering has an experimental firmware release that we hope will resolve the Night Vision false recording issue being reported. I am reaching out to you to offer adding your Arlo account to the field trial list which will allow your system to update automatically to this firmware prior to general availability.
Please return in a private message the email address you use for your Arlo account if you wish to participate in the field trial release.
Opening a case with support is the only way to resolve a hardware issue.
