How do I create a mode for my Arlo Pro Wire-Free camera?
So I have been reading how to make the ARLO Pro set a mode for each camera. Well,I have two Pro's and I can not get them to set up that way. They appear to be set the mode on one, and then both are set the same. I have clicked on each camera, and it does not appear to have anything that shows how to set up the camera mode for each one.
Thank you for any help that you can give...
Steven
The MODE is for the system as a whole. RULES are for each camera within the mode you're using. You probably want to edit the rules, not the mode. You're reading the user manual, yeah?
FAQ's are you friend ; https://community.netgear.com/t5/Arlo-Knowledge-Base/How-do-I-create-a-mode-for-my-Arlo-Wire-Free-ca...
You need to create custom modes to split up the cameras as a group to singles
