Arlo Pro motion detector won't stop once it starts
  • 15 Replies
  • 6902 Views
  • 3 Likes
  • 6 In Conversation
garyh526
I am having issues with one of my cameras. When it is armed to record for motion, it will work properly the first time. Then, it won't stop, even when there is no motion. I have to turn it off. Is anyone else having this problem? I have adjusted the sensor down to about nothing and it still does it. Thoughts?
15 REPLIES 15
mbauer
Do you have sound detection enabled?
garyh526
I've tried it with and without.
mbauer
Try to go into the rules and disable motion detection, save, and then enable motion detection again. I had this exact same issue with one of my Arlo Pro cameras and thankfully this worked for me.
mbauer
I would definitely contact support if that does not resolve your issue. It could be a hardware problem with the camera.
garyh526
This does work for me as well, but unfortunately as soon as it legitimately goes off for motion detection again, it keeps repeating. Just a pain 🙂
garyh526,
Is this happening only at Night or does this happen regardless of the time of day?
garyh526
That's a good question. Haven't thought about it. I guess I would say mostly evenings and night.
The engineering team is currently investigating this issue. We will provide an update as soon as a solution is confirmed.
We appreciate your patience in this process.
garyh526
Thank you so much. Would be nice not to have to constantly reset it! 🙂
Dugsin
My arlo pro is doing the same thing. All the reasons I bought the camera for have been turned off and rain seems to set off the motion and runs until the schedule turns it off or the battery dies. Please fix! BTW new camera old base.
Any help would be greatly appreciated.
Have you opened a case with support?
garyh526
Yes, I have.
Engineering has an experimental firmware release that we hope will resolve the Night Vision false recording issue being reported. I am reaching out to you to offer adding your Arlo account to the field trial list which will allow your system to update automatically to this firmware prior to general availability.
Please return in a private message the email address you use for your Arlo account if you wish to participate in the field trial release.
Joshp
I have this same problem but mine works fine at night. But once the sun rises the arlo camera continuously detects motion every minute till the sun sets. I also have 2 additional cameras that are arlo pro's that i have been swapping around they work just fine so I know it's not because of the location of the arlo camera that is causing the motion recording problem
Opening a case with support is the only way to resolve a hardware issue.
