I have tried all the suggested methods to increase the recording length, including restarting the main unit. There MUST be an easier way to increase the record time from 10 seconds to 300 seconds.
You have to go into the current mode your using and adjust it there ( under record video ). You have a slider bar or check box to use.
BUT, you must hit the BACK on that page and SAVE on the previous page to lock it in.
