Any others experience this or do I have a dud? I'm set on highest image quality and have taken sample videos and pictures and zoomed in on things to compare. Is it because the Arlo Pro has a wider lens and therefore less detail at the same 720p resolution?
I'm just disappointed the image quality is not at least the same as the Arlo, which I never really found to be bad.
I find it looks a lot better than my Arlo cams. The Pro definitely has a massive advantage in low light. The compression does, however, give me some unsharp areas and pixelation of moving subjects, which will suddenly jump to being very clear and then get a bit blurry again but apparently this is something the Netgear engineers are working on. One of my original Arlo cameras had a faulty lens alignment where the right side of the image was blurry but the left side was sharp. I was able to exchange this for a new one that was sharp for all the image
It's still soft around the edges and there's less detail than the original Arlo though. I really think that's down to the wider viewing angle at the same 720p resolution. It's not terrible though. I'm also seeing the blurry-clear jumps on my camera as you stated, but if engineers are working on it, hopefully that can be fixed.
Great that the replacement camera is better. Guess it shows Netgear probably need to tighten their QC process
I do think that the blurry-clear effect is the compression working on Key frames... may be more prone if more movement
