Arlo Pro firmware updates
My newly installed Arlo Pro has a constant message that 'both base station and camera firmware need to be updated', then 'let's start with base station'. it appears to be updating, but nothing happens. It's a constant message that i cannot get rid of. Prevents from seeing 'live' action..
thanks. i've been told internet speed is 1.4mbs to 1.5mbs...
I had the same issue when I set up my system, and again when I added a 5th camera to the system. I kept getting the "Firmware update in progress..." message and I would click the button and wait. and wait. and wait...
I wonder if ARLO has several firmware updates that it must run in sequence, and the message that appears is for each firmware update? Kind of like with Windows security updates that must be dones in sequence? Anyone from Netgear have any input on the firmware update processes?
Djeung,
What was the battery life for the affected camera? Low battery can cause issues when attempting to complete a firmware update. If you are having issues complete a firmware update, be sure the camera has good signal strength and fresh batteries and try again.
Is there a way I can be notified of new firmware upgrades? Do they have a website that lists the latest firmware and what fixes/features are included in that specific firmware release?
Thanks JamesC - but I dont see any Release notes for the Pro Firmware 1.090.0.0_9945 that I am running but my Pro Cameras updated as soon as they were connected. I just wanted to see what this current release addressed versus whatever the firmware that they originally came with. No worries, I will just keep an eye on the thread you noted.
JamesC wrote:sharkcom,
Release notes are available here: Release Notes
Andres18,
Consider removing the battery, reinsert and try completing the update process again. If you still get the same behavior, please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
