Outdoor Security Mount (VMA1000)
I bought two outdoor security mounts and installed both today. One is fine. I'm having problems with the other mount.
I loosened the screw to adjust the camera position. After I adjusted the camera i tried to tighten the screw. No matter how tight i make the screw, the camera does not stay locked in position. I tightened the screw as much as i could and it doesn't hold the camera in place.
what do you recommend?
Return it for a good one
scott_73,
It sounds like there could be an issue with the second mount. Is everything identical to the first? Are there any signs of defect?
