  • 2 Replies
  • 1037 Views
rdsschwarz
I have a Arlo Pro camera and trying yo figure out how to charge it, using cable and charger provided
Plug it into the microUSB port on the back of the camera.
AncientGeek
Hero
Hero
Yes....as I recall, it is a bit odd to get a new battery and a charging cable that doesn’t connect to the battery.  As JGuerdat says...the adapter and cable fit the camera and a camera has to be used to charge the battery unless you purchased the dual battery charger (which I highly recommend)
