I wonder if the new Arlo Pro basestation will support local storage of video shot from the original Arlo wire free cameras. I already have 3 original arlo wire-free and would like to buy a single Arlo Pro camera+base station and move my 3 original Arlo's to it, but will this setup allow local recording of all cameras, old as well as new?
Thanks,
-DC
Yes .... (the base staiton will also be available by itself in the future)... you will be able to local record with the NEW BASE using the older Arlos.
it will work like the Q cams, dual record to cloud and mem usb stick.
2 questions:
- Is there a storage limit on the local storage (new Arlo pro hub), like can I use a 2TB portable hard drive, or does it only accept usb sticks?
- Can I use both local storage and the free 7-day cloud backup to store the video footage?
I am wondering if the old base stations will now also support local backup to USB/ Disk?
Or is this feature only supportet with the new PRO base station?
Thanks!
phankhi,
1. The Arlo Pro Base Station supports a local storage device with a maximum of 2TB worth of storage (storage format must be FAT32). An external hard drive would work in these conditions but be sure to use an external power supply for these larger drives to avoid drawing too much current from the USB port on the base station.
2. Yes. When the local storage feature is enabled, recordings will arrive to both your local storage device and the cloud. If the internet connection is lost, recordings will still route to your local storage device.
auiwowie,
The local storage feature is only available on the Arlo Pro Base Station.
Will the Pro "base station usb storage device" record the video stream continuously if the Pro camera is plugged into an external AC power supply (thus, no battery limitations)?
Can you set recording to continuous rather than 2 min maximum if plugged into external AC power supply?
