How do I turn the Arlo Pro base station siren on or off?
  • 1 Reply
  • 4609 Views
travelerx2
I would like to turn the system off while we are home. How do I turn it on and off while gone? Can I turn off just some of the cameras but not all of them?
You would need to create one or more modes with rules to control whatever cameras you want controlled. Once those are in place, you could manually select which one is to be active or use the schedule if desired. Just don't turn the base off since that will wear the camera batteries down quickly since they will keep trying to contact the base.
