  • 4960 Views
anbumani
My Base station suddenly stopped working initially i tried to remove the device and then add the device but it is showing "Your Base Station could not be discovered." i even tried factory reset but as per the instruction the LED is not going Amber flashing.
Kindly help
anbumani
Now the pro base worked as the instruction in the pop-up says press Sync button and reset button it is wrong for VMB4000 for resetting we need to press Reset button only for 10Sec
anbumani
Now my all LEDs are Green but still i am getting "Your Base Station could not be discovered"
Kindly help
anbumani
anbumani,
Thanks for bringing this to my attention. This is a factory reset method from an older firmware update. Currently, holding only the reset button allows for a factory reset to take place. I have escalated this for correction.
