  • 5633 Views
Tlpollock
I would like to see volume setting in the library while looking at videos and adjusting the volume. When I use the volume buttons on my phone, an indication that pops up of where my volume is and which way it's going when I push volume buttons would be nice. The pop up would disappear after a few seconds. I know it's a very little minor thing.
Tlpollock
It magically pops up the volume indication now when I'm in the library and using the device volume controls. Thank you guys. 👍🏻
Tlpollock,
For video playback, volume should be controlled from the playback device. For example if you are on your laptop you would need to use the volume controls on the laptop to adjust volume. This applies to your phone and any other device you might use for viewing recordings. In short, this is a feature of the device, not the app as it does not control playback volume.
Tlpollock
Several other apps I have used while watching video will have a pop up with the volume slider that moves with the buttons. You are right the device controls the volume , but the app can pop up the volume bar that shows the device volume feedback. It's no biggie, just though this app could show it also like other apps.
Tlpollock
