Arlo Pro alerts me to motion but does not record the motion
  • 18 Replies
  • 8318 Views
JTKHorses
I have 3 Arlo Pro cameras that alert me to motion but do not record the motion. I've checked all of my settings and recently re-synced all 3 cameras. I'm hoping for some advice on how to fix this. This has been going on all week and they used to work perfect. I've not changed any settings.
Open a case with support using the Contact Support link at the bottom here.
18 REPLIES 18
The easiest thing to do first is most cases is REBOOT the base.
Turn off wait a few secs , turn on...let it com back online ( up to 2 mins ) and test
JTKHorses
I forgot to mention I've done that as well, both from the app and by physically pressing the on/off button on the base station.
Then i would take one camera and use REMOVE DEVICE in cam settings
then bring it back as new ,... test...if it functions do the other two also
JTKHorses
That's what I meant I did when I re-synced them. I removed all my devices and then added them back. Still nothing.
The only thing left is to remove the base and do a full reset of the base... bring back as new.
OR
Netgear Support  https://www.arlo.com/en-us/support/contact.aspx
Are the running men for each camera in the Devices tab black or gray?  Gray is disarmed and won't record.  Can you live view and manually record ok? Try enabling both push and email notifications to see if they work.  Push should alert immediately while email waits for the video to upload but provides a link to view.
JTKHorses
They are black. It alerts me that there is motion but it does not record.
JTKHorses
I can manually record and live view just fine.
Do the manual recordings show in the library immediately?  There have been instances of delayed posting to the library - you may be experiencing that.
JTKHorses
Yes they do but I did have that problem a month or so ago but now the triggered recordings don't show up at all (or it's not recording).
Enable push notifications so you can tell if a recording has been triggered.  Then walk in front of the various cameras to try to get them to record - be sure to be close so distance isn't a problem.
JTKHorses
I got 2 of the 3 cameras to record once but none of them are recording consistently.
That could be due to poor connection between the base and cameras or the sensitivity is set too low.  Bring the cameras close to the base and test again for proper operation.
JTKHorses
That makes sense but I haven't moved the location of the cameras or the base station and they both used to work perfect.. What could have changed?
JTKHorses
Also, if the sensitivity is too low, why would it pick up and alert me of the motion?
Additional equip that uses the 2.4Ghz band that was recently installed or moved can contribute to poor signal quality. However, if you're getting push notifications but no videos, that's a whole different kettle of fish.
JTKHorses
So what should my next step be?
