I have 3 Arlo Pro cameras that alert me to motion but do not record the motion. I've checked all of my settings and recently re-synced all 3 cameras. I'm hoping for some advice on how to fix this. This has been going on all week and they used to work perfect. I've not changed any settings.
The easiest thing to do first is most cases is REBOOT the base.
Turn off wait a few secs , turn on...let it com back online ( up to 2 mins ) and test
Then i would take one camera and use REMOVE DEVICE in cam settings
then bring it back as new ,... test...if it functions do the other two also
The only thing left is to remove the base and do a full reset of the base... bring back as new.
OR
Netgear Support https://www.arlo.com/en-us/support/contact.aspx
Are the running men for each camera in the Devices tab black or gray? Gray is disarmed and won't record. Can you live view and manually record ok? Try enabling both push and email notifications to see if they work. Push should alert immediately while email waits for the video to upload but provides a link to view.
Do the manual recordings show in the library immediately? There have been instances of delayed posting to the library - you may be experiencing that.
Enable push notifications so you can tell if a recording has been triggered. Then walk in front of the various cameras to try to get them to record - be sure to be close so distance isn't a problem.
That could be due to poor connection between the base and cameras or the sensitivity is set too low. Bring the cameras close to the base and test again for proper operation.
