What does "access token is expired" mean when I try to log in to view camera activity?
Message 1 of 10
18,780
9 REPLIES 9
Rklepley,
Are you able to refresh the login screen and successfully log in? Can you provide a screenshot of the error?
Message 2 of 10
18,715
JamesC:
I am getting same thing, unable to logon to my system.
It started some time today.
Message 3 of 10
18,286
BTW I do not use IFTTT, I am using Stringify.
Message 4 of 10
18,282
Paul_FCCL,
Force close the app and reopen, are you still seeing the same issue?
Message 5 of 10
18,254
That didn’t do it..........what eventually worked was refreshing “things” within the Stringify app. Problem seems to happen when app hasn’t been used for an extended amount of time.
Thank you.
Message 6 of 10
18,225
Didn't fix my problem. I'm using fingerprint recognition. Works with other apps.
Message 7 of 10
14,016
Hey @KawBoy,
Have you tried to log out, uninstall the app, restart your phone, and reinstall the app to see if that fixes the issue?
Message 8 of 10
14,007
When my token ran out on Arlo (disabling fingerprint recognition), I logged in manually to verify who I was.
Message 9 of 10
13,960
Androïde j6
Message 10 of 10
10,628
