I purchased 4 Arlo Pro cameras with a base unit about 8 months ago. One of my cameras stopped working. But if I plug it into an outlet via the charging unit, the camera operates and synchs to my system. IT WILL NOT function wirelessly, nor will it RECHARGE BATTERIES.
Any suggestions?
check the FAQs;
https://kb.arlo.com/000052305/My-Arlo-Pro-or-Arlo-Pro-2-battery-is-dead-what-do-I-do
Hi @c0w60y
Have you tried contacting customer support regarding this issue & warranty? I have attached the link here for you - Arlo Tech Support
ARLO!!!!!! Your customer support Yes they called me, yes, they troubleshooted the camera, YES they decided it was bad and sent me an RMA to return it for a new one, BUT NO FRIGGIN RMA NUMBER!!!!!! YOU STATE RETURNS ARE NOT ACCEPTED WITHOUT AN RMA NUMBER, BUT YOUR SUPPORT IS TOO STUPID TO PROVIDE ONE!!!!!
Hi @c0w60y
I apologize for the inconvenience, I have attached your RMA# below for your reference. Please let me know if you have any further questions & I will be happy to assist you.
-RMA-643717
