Arlo Pro Stopped recording after 16 seconds during motion/activity
I had an incident at my home and throughout my neighborhood regarding several car break ins and car thefts. My camera luckily picked up the motion in my driveway when the car pulled up to the house. It recorded him for 16 seconds which was long enough to see him start to look into my vehicle and then cut off and it didn't start recording again. I have had these cameras for a little over a month and this is the first time I have truly needed them and I feel like they failed to do their job. I have each of my 5 cameras sensitivity at 75% or higher and set to record until he motion stops. For some reason 16 seconds seems to be the common amount of time that they all record for regardless of motion or activity. I do have instances where they record longer, but each instance is a little different. I do know that most of them that cut off after 16 seconds are cutting off during motion. Any help/suggestions is appreciated. Thank you!
JPC wrote:I did a quick test between "Record until Activity stops" and "Record for a fixed length".. I highly recommend "Record for a fixed length".. Why? There's very little 1-3 sec pause when motion still exist to start recording again.. "Record until Activity stops" however, have 5-10 sec pause when motion still exist and start recording again.. 5-10 sec pause can be a lot of info to miss.. Now, this is my test (Sensitivity - 97 at 16sec length since this is the default on "Rec until Act stops").. Maybe different on yours.. Bottom line is I find "Rec for a fixed length" works really well for me.. My setup is wired with battery inside.. Two Modes [(Morning-Battery/Evening-Wired(Charging)(Rec fixed length - 120sec)].. So far it's been recording at the exact time length.. Quite an improvement than the non-Pro Arlo which I also have and I must say the new Base Station is what made a difference.. Both of my cameras Pros and Non-Pros are perfectly well with this new Base Station..
I am seeing 5-10 seconds easy to start recording with either setting and that is if it catches the motion at all. There are still major gaps between clips. Some times it does not even start recording again and misses.
Try raising your Motion Sensitivity.. You notice my setup Sensitivity is almost in 100%? It needs to pickup that motion else it's going to have a longer pause.. Also, try re-booting your system whenever you do some changes.. Hope this helps a bit
JPC wrote:Try raising your Motion Sensitivity.. It needs to pickup that motion else it's going to have a longer pause.. Also, try re-booting your system whenever you do some changes.. Hope this helps a bit
Been at 100% sensitivity. Have rebooted a dozen times. Its either hardware limiation or bad implementation (software design). Netgear needs to step up, accept there is a problem, and fix it or re-design the product.
I've also tested the motion recording option and it indeed stops recording at :16 even with constant motion in excellent lighting where I was backlit and fully visible. I've changed my settings back to record for :30 on motion. So disappointing.
i have to agree with jpc... fixed length recording at least records for the lenght specified...
can NetGear really face this and provide us update asap?
this is not a setup error and obviously the system does not work as what us, the layman users, expected.
I'm very disappointed with the product and so regretted that i have bought this ARLO so called "PRO" version. 😞
I have escalated this topic to engineering for further investigation. If you have a case open already with support, please provide me with the case number and I will add your case to the escalation for review.
TomMac wrote:I would change it over to a set amount of record time in stead of what your using... 1-2 mins
And if the car their turns his face to the camera 2:01 after the recording starts... then what??
Is it so difficult to make it work to detect intruders??
If you need a case number, I tell you what? I don't have one. Why??
The support hotline is a trash. Those Filipino/ Indian CS just keep asking me to restart the base station and the cameras and wouldn't face the issue that this is a system bug. Everyone of us here knows that this is not a base station restarting problem. IT IS A BUG. I pissed and gave up with the hotline. I don't have a case number. So sorry.
I chose Netgear for my home security since I thought the product is promising and wouldn't bring us down with that money paid. And I really regretted. What being said on the box is not what we expected. It won't even send us notification when someone unplugged the base station. What a nightmare. It literally cannot claim itself as a home security product. 😞 oh well, off topic!
Please have the bug fixed for us asap and bring us all existing customer happy again. This shouldn't be something too difficult to fix. But to us, we would really appreciate it. Thanks netgear, thanks JamesC!!
How do I upload a video?
In library click on share. Then copy link . make a reply and paste link. https://arlo.netgear.com/hmsweb/users/library/share/link/1BC9D28F4DD23780_201707
Time to get the ladder out and remove spider webs lol
Here are perfect examples.
https://arlo.netgear.com/hmsweb/users/library/share/link/7B982D662C8459ED_201707
https://arlo.netgear.com/hmsweb/users/library/share/link/A22032A51991DE2B_201707
Netgear, this is not acceptable.
Adjustments to this feature were made in the most recent firmware release. Be sure your Arlo Pro camera is up to date with the latest firmware: Release Notes – Arlo Pro Camera 1.092.0.4_13099 – 10th July 2017
Please let me know if you continue experiencing issues.
I am running the latest update and still have the problem of recording. It has even NOT recorded motion a couple of times.I have it set at 300 seconds and the most it will record is about 20 seconds. Asfor not recording I was out of town and had a person feeding my dogs,one time it only recorded her leaving and not arriving. Tried to talk to her but she could not hear me.Will post problem with speaker on other thread.
Outdoor --Back door and gate
VMC40301 Pro 1.092.04_13099 Hardware H8
IPhone 6 IOS 10.3.3
Did Netgear ever resolve this?
The resolution is to ensure that motion can still be detected. If the motion has moved outside of the detectable range, recording will stop. You can test this by using the Motion Detecion Test in Settings or by setting 10 second recordings and test the range where the camera will record.
I also am having the same issue. I have only had the cameras for 3 days, and have tried every imaginable combination of fixed time, maximum time, and only record until motion stops. While on "only record until motion stops", the average recording time is 14-16 seconds, and it stops every time - even when there's a car or person walking right in the middle of the camera range, which should not stop the recording. Then, I thought, "well, as soon as the recording stops, the camera will detect motion and will start recording again, right?" No such luck. I am returning them today.
KatS,
How far away from the camera is the object or person you are recording? If they are out of the cameras detection range, this would cause the camera to stop recording even though they may still be visible on the recording.
So, obviously this little "stops recording" issue hasn't been resolved yet. I've ony had mine a few days and the function to record until motion stops only lasts about 15-20 secs. Not cool given what this system costs. And I must have the latest firmware as it had to do that before I could view anything. Is there a fix for this??
I set all my cameras to 100% sensitivity and record for a fixed length of 1 minute. Works perfect, never misses what I need to view. With it set like this it keeps recording up to the one minute even though the motion has stopped, but it's better to have more than needed than to have it stop to soon.
And if you set it up this way and are worried it will drain the batteries too fast because of the longer recording times.....between my 4 cameras inside and my pets constantly setting them off all day long, I still get 3 months out of the battery, easy.
@pc2k17wrote:I set all my cameras to 100% sensitivity and record for a fixed length of 1 minute.
Sorry I misspoke on my previous post. 3 of my cameras inside are set to record for 1 minute, the 4th camera in my attached garage is set to record until motion stops. All set to 100% sensitivity. And they all work perfectly.
This morning my camera in the attached garage, set to record until motion stops, recorded for 1 minute and 46 seconds. This was me walking out the door, locking the door, zipping up my jacket, walking to the car, loading my work stuff into the car and getting into the car. So for me it's working exactly as intended.
If your having issues where it stops recording before motion has stopped my guess is you need to mount the camera at the recommended heights and angles. If set up right, it should work fine. When I first got my cameras I had to play around with height and angle with the one in the garage to get it to work just right. Now it covers motion in the entire 2-1/2 car garage and records until motion stops. Hopefully this helps you. If you still have issues it's possible you got a bad camera.
pc2k17, I wasn't aware there were height and angle limitations. Admittedly, I didn't read the instructions beyond pairing them to the base. Okay...I'll fully read the manual.
