Arlo Pro Solar Panel Charging Faults
I got new cameras and new solar panel by Wasserstein (https://www.amazon.com/gp/product/B074KFZYJJ/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1) and getting this error all the time "A charging fault has been detected on Driveway camera. Unplug and reconnect the charger from the camera side of the plug. If this error message persists, see KB article for Charging Faults."
Tech support does not seem like has a clue 😞
Did anyboidy find a solution to this issue?
Thx
Not much to do...the specs on a third party solar panel may not be the same as one produced by Netgear.
Other than what your doing and/or the panel may be defective
Wasserstein tries to make everyone believe that their products are Arlo approved, which they are absolutely not. If you read the reviews on Amazon, you will see that their products are cheap Chinese made items. Some people, maybe 50% give their products good reviews, I surely would not trust them out in inclement weather.
Brian
The problems is that I tried netgear panle awhile ago and it was having similar issue !!
@brhwrote:Wasserstein tries to make everyone believe that their products are Arlo approved, which they are absolutely not. If you read the reviews on Amazon, you will see that their products are cheap Chinese made items. Some people, maybe 50% give their products good reviews, I surely would not trust them out in inclement weather.
Brian
Do you have a solar pan that works well and chnagres Arlo Pro ? Pls suggest !
Yes, the Arlo solar panel. I have 2 Arlo Pro cameras using these and am about to mount another Pro camera using Arlo's solar panel.
Brian
@chudak Yes, I believe that is the correct one. Rather than buy off of Amazon, if you have a Best Buy near you, you can run out and buy one tonight. The Arlo one will come in a box with the Arlo hummingbird logo on it.
Brian
I have 4 solar panels that worked fine for a few months then 2 of them started to get error messages and wouldn't charge. I tried everything possible but to no avail. About 3 weeks ago, the problem mysteriously went away and they are all working fine. This leads me to believe it was a software issue that was addressed on Netgears end.....................hopefully.
I have a system with 5 cameras. One is plugged in. Other 4 are connected to solar panels. Running 9 months. Since yesterday 2 cameras are losing charge, not charging - no lightning symbol - and give message “ charging fault”
Mediocriollo,
Have you tried to connect the 2 trouble cameras to the other solar panels to see if the error is still there & vice versa.
