Disable alarm button on Arlo App
Is there a way to disable the alarm button? I'm concerned that someone may accidentally press it due to placement. Or is there a secondary warning that lets you know that you are about to set off the alarm?
the alarm button on ios is now a pull down tab, IIRC
The alarm button is now a pull down tab, so very hard to accidentally tap it as you have to pull it down first. But even if you did it asks to confirm that you want to do that. Accidental set off is basically not possible.
