While using Schedule mode, if I change the current time period from Armed to Disarmed or vice versa, the displayed mode status is not updated until I force close and reopen the app.
Thank you, Shayne; the mode display issue was fixed in the latest app release.
Have you tried to reboot your base station & test again? What Arlo Mobile App/IOS Version are you using?
Yes, I tried both a power restart and software restart. iOS v12.1.2, app v2.7.0
Have you tried contacting customer support regarding this issue? I have attached the link below for you - Arlo Tech Support
Anyone who has spent any time on this forum knows that contacting customer support is a waste of time. I've reported the issue here; the company has the info they need and should fix it. I'm not the first person to report that mode scheduling doesn't work properly.
Due to the amount of issues described I have opened a case for you. Customer Support will be contacting you as soon as possible.
