  • 7 Replies
  • 5716 Views
Trigger78
While using Schedule mode, if I change the current time period from Armed to Disarmed or vice versa, the displayed mode status is not updated until I force close and reopen the app.
Trigger78
Thank you, Shayne; the mode display issue was fixed in the latest app release.
7 REPLIES 7
ShayneS
Have you tried to reboot your base station & test again? What Arlo Mobile App/IOS Version are you using?
Trigger78
Yes, I tried both a power restart and software restart. iOS v12.1.2, app v2.7.0
ShayneS
Have you tried contacting customer support regarding this issue? I have attached the link below for you -  Arlo Tech Support
Trigger78
Anyone who has spent any time on this forum knows that contacting customer support is a waste of time. I've reported the issue here; the company has the info they need and should fix it. I'm not the first person to report that mode scheduling doesn't work properly.
ShayneS
@Trigger78
   Due to the amount of issues described I have opened a case for you. Customer Support will be contacting you as soon as possible.
Trigger78
ShayneS
@Trigger78
That Is great to hear!
