  • 5 Replies
  • 6083 Views
sheila13
Camera seems slow to notice anything.
Should sound be on?
what is a yellow man?
does the app have to be active to get a notice?
what part of the camera notices the motion? -- center eye?, right light that blinks when syncing, or the hole to the left of center?
Is live chat available?
Is there a way to request a call?
Thanks for your help
Camera seems slow to notice anything.  placement is important to allow good response, the Pro is pretty good re the response time
There is and adjustment for sense level too
Should sound be on? Only if you want it...toggle on or off your choice
what is a yellow man? Yellow Man is the icon that shows the camera is recording , Black is is motion detect on, gray is off
does the app have to be active to get a notice? No the app doesn't need be on , but motion detect must be to send a push or email when triggered
what part of the camera notices the motion?  bottom black area below the lens...it covers the entire field of view
Is live chat available?  Yes if you mean to Netgear... via the CONTACT SUPPORT page ( button at top or bottom of page ), also email and phone
Is there a way to request a call?  answer just above, same answer
5 REPLIES 5
sheila13
Thanks Tom,
Where do I set the sense adjusttment?
And where do I set this: " motion detect must be to send a push or email when triggered"
I'll try the chat and/or call on Monday -- perhaps no answer as this is the weekend.
FAQs are your friend... https://community.netgear.com/t5/Arlo-Smart-Home-Security/ct-p/Arlo#    ( down page half way, title bar )
https://community.netgear.com/t5/Arlo-Knowledge-Base/How-do-I-change-the-motion-sensitivity-on-my-Ar...
In MODE, means must be ARMED otherwise there are no trigger events (motion detected ) and no alerts
https://community.netgear.com/t5/Arlo-Knowledge-Base/How-do-I-set-up-notifications-or-alerts/ta-p/10...
sheila13
Tom, thanks for all your clarifications -- all has been helpful.
I now am trying to learn how to set a mode so I can record for more than 10 seconds.  I did view a video that explained this, but now cannot find it.  Would you happen to have a link to that.
And, re:  the other question I posted about the fatal error message --
        Still getting Fatal error message on Mac Air and iPad --   now on hold for a phone call -- hopefully this will help.
Thanks for your help.
https://community.netgear.com/t5/Arlo-Knowledge-Base/How-do-I-adjust-Arlo-video-recording-length/ta-...
all in the FAQs...
If the fatal error was late last night/ this morning...the servers were down causing issues
