Arlo Pro Outside Siren
Anyone know how to get the siren to an external speaker so you could have a speaker outside that would sound the alarm outside also.
Seem sorta limited to not have away to wire the speaker to an outdoor sound speaker so when alarm goes off it would be outside also.
You probably need a third party speaker and to use something like IFTTT or Smartthings
How would you hook it to the base unit?
Thanks LIndel
You wouldn't. It would need to be triggered via software such as an IFTTT command.
So with the currant model there is no way to do it now is what you are saying correct?
Lindel
AmericanGreenLC wrote:So with the currant model there is no way to do it now is what you are saying correct?
Lindel
Not with a direct wired connection. You can with a more complex home automation and app system
Sorry I dont know what that is. Is it a add on that someone would have to do for me or is it a part of the Arlo family?
How would one do it?
Google IFTTT and/or SmartThings for more information. It's not part of Arlo systems other than the ability to interact with the appropriate hardware and software. Basically, there's a separate controller in your home that can be configured through software to cause disparate devices to operate with each other.
Also check out Stringify. It incorporates IFTTT but adds a lot more features and abilities with a pretty easy to follow interface
here's something I'm thinking of trying as a work around... connect a wireless speak or wireless horn (if you can find wireless horn great)... using a karaoke center (that has blue tooth capability), you connect to the wireless speaker. Leave your microphone on, near your base. They make some small ones now ... in this way, anytime, the siren goes off, it plays through your wireless speaker... no smart home stuff to worry about.
