- 2
I am very frustrated with this problem. I DO NOT have time to troubleshoot for hours, and I need this system to work! I have already been through the RMA process for one faulty camera- I had to pay shipping for a camera that was faulty from initial purchase! I will not do the RMA process again. I WILL NOT recommend this system to anyone, unless ARLO gets this bug worked out.
I have tried everyting that has been suggested online and thus far still have the problem! It may well be a firmware issue but I don't know why it does not effect every camera as the other four are working fine. I may need to ge into this "experimental" status as well. I will follow your progress
techie61,
I have not been able to replicate this behavior. Are your cameras Armed and being triggered by motion? It sounds like your cameras are detecting motion as expected while you are attempting to use the motion detection test feature.
techie61,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
- 2
