Arlo Pro: Motion Detection every minute
Reset the camera by pulling the pack and replacing..
If still NG, then remove the device in settings using REMOVE DEVICE and bring back as new.
Then if the problem continues, contact Netgear Support as it may be bad.
I have 3 camaras. Same problem. At night the camara keeps detecting itself and firing up the video and alerts over and over - depending on the recording time set this can happen several times a minute. It's clearly the infra red detection; maybe because it's been raining or near a shiny surface (like a window - though mine's not pointed at it). This must be a bug in the software which needs looking at. Only way to stop it I've found is switch camara off and then on again a few moments later. Makes the camaras pretty useless at night.
You might be experiencing this:
The engineering team is currently investigating this issue. I will post an update with more information as soon as I can. We appreciate your patience in this process.
The engineering team has identified the root cause and has been able to reproduce this issue. I will provide an update once I have more information on a fix.
Thanks. I'll turn off night vision for now to save battery life throughout the night. Hopefully this is a firmware "fix" and not a hardware "fix".
This started happening on my Arlo Pro both day and night a few days ago. Hopefully the engineering fix is forthcoming.
This is happening on 2 of my cameras. Once i disable night vision, I don't get the motion detection anymore. As soon as i enable night vision, the motion detections starts up again every minute.
My Arlo Pro (which is a replacement for a previous defective one and I received yesterday) is also now detecting motion virtually every minute unless I
turn the camera off. This occurs at night as it did not happen, but once, during the day today. There seems to be no way to predict when it will happen so
I have to leave the camera off .
Get it replaced again.
Thank you..
I have opened a support ticket with Netgear.
Exactly my experience with 1 of my 4 cameras bought 4 weeks ago! Sending the one back for replacement.
Since my camera was still in the 14 day period, i was able to return the 4 camera set back to Best Buy. After mounting the new cameras, same issue. Once it got dark, after a valid motion detection alert, the motion detection started sending a motion detection every minute. i went to check and it happens on all cameras.
Disabling night vision solves the problem of the constant motion detection.
Arlo Pro: Hardware H8, latest firmware 1.090.0.0_9945
Hopefully they fix this. I have another 14 days to return it. This time, i might return it for good.
I also disabled Night Vision on the affected camera, but the camera still sent the frequent Motion Detection alerts. My other Arlo Pro is not affected
at all with this issue. I notice it has a hardware # of H7 and with the same firmware as the affected camera, but the affected camera is hardware H8..
Maybe hardware H8 cameras are the bad ones ??
Waiting for support to hopefully let me return it for another one
I don't know if returning the camera for a new camera with the same firmware/hardware will solve the problem. I just did that and the new cameras do the same thing at night when night vision is enabled as the one's I returned.
I have another 14 days to return this. If they can't fix this issue during that period of time, I'm force to return it back and try a different brand. I like these cameras, but if night vision doesn't work and i can see anything, whats the point?
Add me to this list. One of 5 cameras does this all night - just checked and I have 260 1 minute videos of my driveway from last night.
I've tried this camera in two separate locations (backyard vs. driveway) and it does the same thing. Another of my cameras works just fine in these locations - they both have the same settings and firmware/hardware.
Why would only 1 of 5 cameras do this? This suggests a defect, not a firmware/hardware issue....
I have opened a support ticket for a replacement. I do not want to have to return the whole kit, just get the one camera replaced......
I sit corrected.
I meant to just say 'firmware', but guess I got carried away typing....
The engineering team is currently investigating this issue. We will provide an update as soon as a solution is confirmed.
This is good advice and I certainly will try it. Thanks a lot for the reply!
TomMac wrote:Reset the camera by pulling the pack and replacing..
I wound up doing all that, and still had the problem, so am now in the process of becoming 'experimental' status on my system for Netgear to push a possible firmware fix - am awaiting that now...
