Unable to navigate to different months in library. Currently can't navigate past May 1st. Any ideas?
Do you have the free 7 day plan? We're on day 8 for May so previous months won't show. You'd need to upgrade your plan to see further back.
I thought I upgraded long time ago but come to find out I only have basic. Thanks for the reply!
I have this issue also
Today is the second, and there are no < > to change months.
I am using safari browser
You cannot look at library recordings from the previous month
I am having the same issue every month. It is June 3rd and I haven't been able to veiw any of the recordings this month. My library is stuck on May 31st.
What client are you using that is experiencing this issue (web, Android, iOS)? Do you see the same behavior across all clients?
It’s works fine using iPhone app
swf,
You may need to clear your browser cache. Are you still seeing the same behavior on your browser?
I have also noticed this seems to happen at the end of each month but if I stop and restart the app on my phone it can then see the new days for the current month.
