Arlo Pro - I can't use the web interface.
  • 8 Replies
  • 8063 Views
  • 5 In Conversation
uniqueuts
I tried the latest versions of Chrome and Edge.  Both browsers redirect me back to the login page.  It appears Flash is the problem.  Chrome shows flash is block and Edge requests that I download the latest flash but when I click the link, nothing happens.
Is there a fix?
Redmoonstar
Luminary
Luminary
 Are you running Kaspersky Internet Security on your PC? If you are you need to go into the settings in Kaspersky and allow Arlo. You need to go into Kaspersky - settings - protection - web anti-virus  - advanced settings - configure trusted URLs and add  https://arlo.netgear.com/
Hope this helps.
8 REPLIES 8
steve_t
Master Master
Go into Chrome settings and set the web address as an exception to the Flash blocking
chrome://settings/content
uniqueuts
Do you have any other ideas?
uniqueuts,
That first toggle needs to be turned on so that instead of saying "Block sites from running Flash" to "Ask first (recommended)".
uniqueuts
The screenshot below shows that I toggled what you said to toggle.
When I visit the ARLO page to login, it reverts me back to the sign in page and in the address bar, this appears:
What else can be wrong?
uniqueuts,
Try clearing your browser cache
Do you still see the same behavior?
Redmoonstar
Luminary
Luminary
Hope this helps.
JoeCymru
Virtuoso
Virtuoso
Symbol is Adobe Flash error.
uniqueuts
Thanks, this fixed it!
