Arlo Pro Charging Faults
One of my 3 cameras is not charging. It shows it is charging, but stays at 20%. I synced it to the base, and took the battery out and back in. Help. Frustrated. System is only 6 months old and the other 2 are ok.
Swap batteries around to see if it's the battery or camera.
Thanks, I swapped out to the extra battery that came with the set and that worked. Disappointed that one battery only lasted 6 months. Maybe I can send it back for a replacement?
