  • 7326 Views
RHARLO
Arlo Pro Camera VMC4030, AC Adapter AD2085320, battery A-1
I keep getting a charging fault with instructions to read articles. I have tried removing battery, unplugging the cable from camera, and from the wall in various combinations, turning off the camera by my arlo app, still showing charge fault. I am using original packaged cables, ac adapter, and camera, and battery pack. I am down to 29%.
RHARLO
I do not have another camera and didn’t want to throw my money away ordering things that may not help. Tried several solutions, all failed. My solution, I moved the camera to another location, removed the battery, and leave it plugged into an electric socket.
AncientGeek
Hero
Hero
If you have another Arlo Pro, try swapping batteries.   If the problem doesn’t move with the battery to the other camera, try swapping the charger and cable between cameras.  If, after that, the original camera with a different battery and different charger and cable, still fails to charge, you have a bad camera.
RHARLO
If you don't want to spend the money, why on earth don't you contact support for a warranty claim?
