I bought these cameras to be able to speak through them and have people or dogs easily hear. We can't barely hear the voice through the cameras. I have the most recent firmware and it's still so low. How can I increase the cameras speaker volume?! Or should I return them?
Alot depends on the device used for the transmission of audio...
A PC whaich has an audio gain option works well... Android and or IOS are model specific as many times the gain is fixed.
Try a wired mic to the device if you have one or try speaker phone
I have same issue and try with different devices (Iphone6, IPAD pro, other IPHONE6) and all have same result which is low volume speakers from all my 3 Arlo pro camers
booaoof,
Take a look at your cameras volume settings. Log in to your Arlo account and navigate to Settings > My Devices > select the desired Arlo Pro > Audio Settings > make sure speaker volume is turned up.
I am looking for your support, please.
I find the volume is fine for indoors but not out. Use of a computer, where you can increase mic gain unlike on a mobile device, works much better for outdoors.
Agreed it works much better with an auxillary mic attaced to a phone. I just used a bluetooth set and it was much better. I prefer to not have a headset on all the time but this does lead me to think the android and apple apps need to be improved.
Logic would dictate that reversing the roles of both mics would lower the output to the Arlo Pro cam. The rear mic on the iPhone is used to detect background noise and erase it from the main mic. If you reverse this, the main mic would pick up louder sound and cancel out the rear mic almost completely.
This is most likely the cause for the whisper quiet output from the Arlo Pro can. Netgear needs to correct their application!
Firmware updated
Volume set max 100%
2x Samsung Galaxy S8+
Muffled low volume
Barely understand anything even when absolutely quite.
Cameras turned off removed battery, resynced to be station, back on, still terrible sound. Uninstalled and reinstalled app on phone, still terrible sound.
This app need to be fixed immediate.
I have same issue. Also, it takes several seconds to get a notification on my phone. A few seconds to view the video as it loads. Add another 5 to get my response, and the person is gone.
It's a feature that's really NOT useable.
Upgraded to an S8 Active, works fine. Only difference is the phone. That's why they aren't "fixing" it...their app can't physically change the mic gain level on the phone.
I suspect newer camera versions will come with larger speakers to compensate.
If you don't believe me try it with a laptop and plug in microphone. Turn up the mic gain level and it will work fine.
When talking to tech support they tried to tell me they did not specify how load the speaker should be, which was a BS excuse. The sound is so low and do poor it is obviously far far below and practically variance.
I have the same problem with a brand new Arlo pro. Sound is too low for anyone to here you. Support couldnt seem own up to there even being a problem. Said I had a bad camera and that the camera had to be within 3 feet of the person. Well I had it up to my ear and could bearly hear it. It also has the latest firmware from october 2017. Support logged into my account and spoke thru the speaker and it was louder but I figure they had some sort of gain on hteir end. Could be a problem with the app it self. They are sending me another camera. If its the same way Im returning the whole thing. No need to pay all that extra money for a pro if the speaker doesnt work.
Jess
Not netgears fault? Maybe they should have tested it with more phones before they started selling it. Or even list compatible phones. The video is great but I bought it for the mic and speaker. Too much extra money for something that doesnt work.
1. the present circuitry is NOT capable of producing the ~1 watt of power needed for powering a proper speaker. Microphones use slightly different physics.
2. Such power needed would dramatically reduce the service life of the current Arlo battery.
3. The company may have misrepresented the utility of THIS feature.
4. There is NO ability for current Arlo CIRCUITRY to resolve the issue.
So, it is what it is as its said.....
If using two way on a computer, it works fine. It’s actually loud and clear; even without setting a mic gain. I have a great feeling that since it’s hit or miss for some mobile users, it has to do with Netgear not coding their application correctly per platform/version.
