Hi @An6y
Have you tried pairing from the web portal as well? Does your hub have a blinking Blue
light as well?
Have you tried removing and resyncin g the camera rather than just trying to resync?
@jguerdat The camera has blue blinking light. The hub does not have blue lights. It has orange and green. The camera light blinks green which shows that the hub is searching / syncing with a camera.
WHat one is amber? That may be the real clue.
@jguerdat The camera light is Amber when no cameras are connected. Once I’ve synced another camera the camera light blinks green when attempting to sync the problem camera.
If the Camera LED is amber, that means the base isn't claimed. You say you reset the system so you must first claim the base and then sync the cameras. Depending on how you reset, make sure all devices in Settings, My Devices are removed first.
@jguerdat That’s correct. I have removed the base station, reset the base station and then reconnected to the base station before attempting to sync each camera. I have synced each camera and they work as normal except the problem camera.
Seems like you've tried everything. Use the Contact Support link at the bottom here for a possible hardware problem.
