Arlo Pro Camera losing charge more rapidly than Arlo Pro 2 camera
I have 8 Arlo Pro cameras and 1 Arlo Pro 2 camera. If I charge them all on the same day, the Pro carmeras battery lives are from 64% to 77% and the Pro 2 camera is at 92% after 1 week. This problem just started a few months ago after the notice about the security update. All 9 camera used to lose their battery life at the same rate. I have swaped bateries around, tried best picture and all the other tips to save battery life even unistalling a camera & re-installing it. The lower resolution Pro cameras battery life lasts only 3-4 weeks even if the camera is disabled. Is anyone else having this issue?
I would assume that netgear is aware of this and I hope they are working on a update for the Pro cameras. It's very aggrevating to keep having to charge 8 out of my 9 cameras every few weeks. Thanks.
New firmware out today....... hopefully it helps you guys......
Just remember 300 feet is if there is no interferance from other devies and if you have no walls, doors, windows, objects, tress, etc, in the path between the base and camera. Once you add just walls the range drops.
