- Email to a Friend
Hi, folks
I'm having problems with the audio breaking up during live feed on my Arlo Pro 2. It's ok during playback. Video is ok. My internet wifi upload speed is around 0.9Mb/sec (7~9Mb/sec download). The sound breakup is rapid, like fast morse code being superimposed on the audio. My morse listening skills are not so good, but I hear a lot of "f"s (seriously). It happened about 2~3 months after installing the system. I even had a telephone serviceman look at the line to make sure it wasn't a line problem (I have ADSL2+ through copper cables). Anyway, it was working fine before. Something has changed and I can't figure out what it is.
Hope you can help
Best wishes
Q.
- Email to a Friend
Guess what, Netgear says Arlo is no longer part of them as of this week. Go figure. I talked to them today at length and got the same story (at least it is consitant) "Even though it worked before we upgraded it, your current system isn't capable of handling our new upgrades that make our system even better, we can't help you. " I'm going to tkae mine back to Costco and see what they say and look for something less expensive and more reputable.
All Replies
- Email to a Friend
At 0.9 you are really on the lower edge of the range and this could very well be the cause of the problem you are experiencing.
Your ISP will give you an indicative speeds but it can vary quite a bit. When one has lots of bandwidth it wont really make a difference but when you are as low as 0.9 it certainly can.
Use speedtest to test the speed at different times of the day and when you find it faster then see if you still experience the breakup.
- Email to a Friend
Thanks. Unfortunately, this is the fastest upload speed I've seen. I get less during peak hours. Seems I should have read the fine print
Just seems odd that the cameras were working pretty good for 2~3 months, then went bad. In some situations (now), I lose control of the cameras (can't turn them off after activating them). I have to run home and depower the system completely before I use up my monthly data allowance.
Anyway, thanks again.
- Email to a Friend
Minimum requirements for the Arlo support page:
A high-speed Internet connection (minimum 1 Mbps upstream recommended).
Note: Arlo works with the minimum requirements, but the functionality and video quality might be negatively affected. The lower your upstream bandwidth, the greater the possibility of the following performance issues:
- Video quality might be pixelated and unclear.
- You might experience a delay in a live stream.
- Email to a Friend
I think less than 10% of Australians have more than 1Mb/sec upload speed. Perhaps there should be a greater emphasis on the limitations when this product is being sold here?
- Email to a Friend
Qavion...
I have the same issue with the Arlo Pro. The audio breaking up is your video freezing for a second. Mine started doing it about a week ago. Only when live streaming. I've had the Arlo for about a year. No issues. I've also got fairly slow internet. On a good day I'm running .7Mbps upload speed. I just can't get any better where I live. I knew the speed requirement when I purchased the system, but I figured it was worth a shot. I spoke with someone at Netgear Friday, and they advised me that it was due to my internet speed. They couldn't tell me why it hasn't done it until now. I've got my fingers crossed that it has something to do with this latest crap update that they put out. If not, us slow internet folks will have to get something else.
- Email to a Friend
Thanks, Jason. Good to hear I'm not alone.
The video seems to be ok. It just takes a while to catch up. The motion sensing seems to be ok, too. I get warning that there's someone there, but there's no way I can communicate with them in real time because of the delay.
I think my problems started well after I did the software update, but I live in hope that the next software update will help 🙂
- Email to a Friend
I am experiencing the same problem. with the Arlo Pro. Audio stream sounds like morse code. I also have DSL 5 meg down and 1 meg up with AT&T. I've had my system for awhile now without any problems at all until about 2 to 3 weeks ago when the stuttering started. I wonder if Netgear pushed a firmware update that is causing this?
- Email to a Friend
Looks like it was due to their last firmware update. Support asked me to post a video showing them the issue last night. I tried, but the recording obviously won't show the delay, and the paused portions of the video don't show up during playback. I recorded a 30 second clip, 16 seconds of the recording were paused or cut out, so the video only ended up being 14 seconds long. So frustrating.
- Email to a Friend
I've had the Arlo Pro for a year and never had the breaking up audio. Noticed the sound became choppy after the firmware update. Terrible and very annoying when viewing live feed. Arlo, please fix.
- Email to a Friend
Support was working with me to try and find a fix. I've been updating folks on another thread. Support has quit responding now. Looks like they have no clue what is going on. They break their own product and then have no clue how to fix it. Great.
- Email to a Friend
I am having exactly the same problems with Audio monitoring. I have 3 sets of cameras at various locations. For 12 months I haven't had any problems, but for the last 3 to 4 weeks all locations are having the same problem. If you leave monitoring on for about a minute, the audio stuttering stops and you receive clear and unimpeded sound. Although it will revert back to the stuttering every couple of minutes. Its got absolutely nothing to do with internet connection speeds. It is clearly an Arlo server issue as it routes traffic. Maybe a result of a spiking uptake of the product. I don't expect Arlo support to be fessing up to their own server issues any time soon. And hoping that they upgrade, repair their systems in the next weeks. Lets wait and see.
- Email to a Friend
These folks are unreal. Just can't stay out of their own way. I had a support tech helping me troubleshoot this issue. He offered to send me a new camera to test. Asked for a few additional pieces of information before he did. Then they launched their new my.netgear.com site, and the support case was erased. I can't respond to the tech at all. Incompentence at an amazing level
- Email to a Friend
- Email to a Friend
- Email to a Friend
Since the recent Arlo f/w and/or app update (2.5.4) the live playback while using the mic for 2-way audio is extremely choppy on my iPhone w/ iOS 11.3. Both the audio and video start lagging really bad. If I do not engage the mic everything is fine. This happens while I am on LTE with 30 Mbps down / 15 up or using my phone on a wifi hotspot with 90 Mbps down / 90 up. Base station has been rebooted multiple times - no change. This is yet another Netgear bug introduced.
- Email to a Friend
I am half glad to see I am not the only one having that problem. Exactly the same symptoms : all was ok for a couple of months, and recently I get a choppy sound and video. I even tried to lower down the Video quality to the "long battery life" setting, but it did not help at all.
I am concerned that no sound is coming from NetGear on that topic (even a little choppy ! ^^). Are they working on a solution or are they just not interested ?
I was contemplating to buy another couple of cameras, but not in that conditions !
T.
France
- Email to a Friend
- Email to a Friend
Continue to have the same problems as everyone else is describing with Arlo live feed since the mid-May firmware update. I wonder if this is at all related to the roll out of the new Arlo Smart service/functionality?
- Email to a Friend
- Email to a Friend
After upgrading to VDSL (18Mbit UP) from ADSL (1Mbit UP) everything is good now. I know that doesn't necessarily rule anything out, but at least it demonstrates the system can provide a good quality result without other changes customer side. Of course there could have been provider side changes in the meantime.
- Email to a Friend
Thanks for all the responses, guys.
I'm sure changing to a faster connection will help, but there seems to be quite a few guys who had no problems on 0.9Mb upload speeds, then, after the software (firmware?) update the sound started to break up. Does the new software demand more of our connections?
- Email to a Friend
Hi Qavion, There is a significant issue here that Arlo support is not addressing. Something their end happened in May. It is a common problem it seems. It occurs to me from 3 sites at all times of the day/night, 7 days a week i.e. it is not a product of traffic congestion.
Recommending everyone upgrades from ADSL/2 to get a clear audio is completely unrealistic and not helpful.
Arlo support needs to confirm the issue, address it and make recommendations. If they now suggest that you need a better connection to get one of the key features, they should say so. It certainly would significantly change the value of the offering.
- Email to a Friend
Mine started sounding terrible sometime around May. Something definitely happened. Very disappointing. I can stream movies all day long but my live audio sounds like garbage now. Going to probably look at other manufacturers/products. The detections doesn't work as well either. Watched the UPS guy walk past three cameras and none detected him. I didn't make any changes to the settings that used to work. And YES the system was "Armed" on all cameras.
- Email to a Friend
