  • 4 Replies
  • 12326 Views
jeffharris
One of my Arlo Pro camera went off line and would not synch. Tried 3 different sets of batteries.. Light blinks blue indicating cannot find base station when it is next to base system. Removed device, Tried to add back, but same issue with blue blinking light. What can I do to reconnect this camera?
jeffharris
Unplugging base station for 60 seconds and restarted.  Then, I was able to add the Arlo Pro device back to the system.
Closed this log.
mustangalbee1
ChaChanged batteries can't get to sync back in
Try resyncing it. Be sure to only briefly press the base syncbutton - don't hold it. You may want to reboot the base, too. Worst case, remove the camera from Settings, My Devices and resync.
jeffharris
Have tried to synch for two days, but only get blue blinking light.  Was able to synch new doorbell and chime without any issues.  All other cameras are functioning, but not this one.  Was working on 24th.  Lost Connection.  Will not synch.  Is there a Factory Reset on a Arlo Pro camera?
jeffharris
Closed this log.
