  • 5 Replies
  • 4907 Views
  • 5 In Conversation
Yenhc3
My Microphone disappeared , i guess bc of the new update?? so i deleted and re installed the app, and its re appeared
but now it says
" Your camera speaker is disabled.
Go to Camera Settings to enable."
Where can i find this option?  its not on the actual arlo app, i went to settings on my Iphone 6s, and cant find it anywhere!  i keep reading other peoples comments on this and cant find an answer, has this problem been fixed? help please 😉
5 REPLIES 5
Jake03
I had the same problem two days ago. Looked everywhere for the setting. Go to your settings in Arlo (not on your iPhone) and turn the audio setting off and on. That should work
Yenhc3
I tried that too!! i turned it off and on.. at least like 3 times. then i kept restarting my phone to try it and it still isnt working
Bkmunger
This is my problem too, it's very frustrating, I am going to call customer service to see if they can fix the problem
Check with a browser, too.
Yenhc3, Bkmunger
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
