  • 2273 Views
Jogilgo
When I charge the battery in another camera , the battery seems to be fine. I suspect the camera usb connection may be bad?
Sounds like a hardware problem. Open a case with support here.
ShayneS
Jogilgo,
Did you test the second camera with the same charging cable as the Camera that will not charge? Is this cable you are using the original from Arlo?
Jogilgo
I have tried 5 original cables, I have several arlo pro cameras and this one is the only one not charging.
