Arlo Pro Camera Battery Charging Question
Hi, I have the outdoor Arlo Pro camera. I plugged in the USB cable to charge the battery. Can the camera be permanently plugged in so it runs off electricity and not battery? Right now I have it plugged in so I thought the battery was charging but then just got a notice that the camera is low on battery. Thanks! Katherine
You may have the battery out while charging the camera if you choose to do so. Are you using the original AC adapter and plug that came with the camera?
