Difficulty Logging In with latest Apple iPad Pro 12.9 inch model
  • 1 Reply
  • 1064 Views
Concorde
When you start the Arlo app (v 2..6..3), there is a problem with the login screen. There. Is a field for the user Iid and password . But, the login is button is missing on the screen. So, no obvious way to login to the app. The only way to login in is to pinch the screen. Doing this will uncover the hidden login button. While pinching the screen , you enter your login credentials and use the login button. This needs to be fixed .
ShayneS
