With the Arlo Pro camera, can regular (non-rechargeable) ni-cad batteries be used in place of the rechargeable battery?
No. You'll need to use the battery pack provided. And where have you found non-rechargeable NiCd batteries??
8 REPLIES 8
I meant rechargeable akaline batteries - sorry.
Non-recharable akaline batteries.
nope...the pro has a proprietary battery
How long does it take to recharge?
a little over 2 hours
How long does it last between charges?
Depends on hjow you use it. Live view and recording times all get in there - 5 minutes per day should give you 2-3 months.
